Can't retrieve data from ASL EyeTracker
Dear community,
I'm having issues retrieving data from an ASL EyeTracker. Everything works fine, uploading and calibration, until I try to get the data. After calibrating, I save the config as asl.xml in the same folder as the script supposed on [1], which raises an error when I try to run it: Code:
ERROR: Failed to connect to ASL EyeTracker (Cannot create XML parser. Please install MSXML4 from http://msdn.microsoft.com/XML/XMLDownloads) ERROR: Failed to create extension sensor with asl.dle Thanks very much, regards [1] http://docs.worldviz.com/vizard/ASL_Eye_Tracker.htm |
Is the ASL software running when you run the Vizard script. If so, try closing it down first.
Similar Threads | ||||
data lose | psykoko | Vizard | 3 | 12-16-2010 08:08 PM |
Use saved text file data as replay sources problem | mizutani_jun | Vizard | 4 | 10-14-2010 04:49 PM |
Using 5DT plug-in with the data coming through network... | mcicek | Vizard | 1 | 05-18-2009 05:17 PM |
Flagging the Data | Elittdogg | Vizard | 5 | 04-11-2008 11:40 AM |
tracking using quaternarion data | jfreeman | Vizard | 2 | 06-01-2005 08:48 AM |
