To Masaki regarding render nodes
I am trying to render a virtual environment on a render node that is located within another virtual environment. Both worlds need to run simultaneously, one on the render node, and the other on containing the render node. How is this task accomplished? |
Here is some sample code to get you started. This will create two different environments (scenes). One has the piazza and one has the dojo. The rendernode will render the dojo scene within the piazza scene.
import viz viz.go() #add a world world1 = viz.add('piazza.osgb') #add a second scene scene2 = viz.addScene() #add a second world and set to it the second scene world2 = viz.add('dojo.osgb', viz.WORLD, 2) #add a render node renderNode = viz.addRenderNode( ) #set the scene of the render node to 2 renderNode.setScene(2) #add a render texture at 512x512 resolution renderTexture = viz.addRenderTexture(size=[512,512]) #attach the rendertexture renderNode.attachTexture( renderTexture) #add a texture quad quad = viz.addTexQuad() #add the rendertexture to the texturequad quad.texture( renderTexture ) #position the texture quad quad.setPosition(0,1,0) viz.MainView.setPosition(0,1.8,-3) |
Similar Threads | ||||
How to render a texture of the transparent object and then blur it | whj | Vizard | 1 | 09-25-2012 03:15 PM |
re: render nodes and scenes | nige777 | Vizard | 2 | 10-18-2010 01:14 PM |
How to apply shader and render texture to an object | whj | Vizard | 0 | 04-23-2010 12:23 PM |
Internal nodes of loaded model files? | dtidrow | Vizard | 2 | 05-12-2009 08:55 AM |
Collision with child nodes | rubberpimple | Vizard | 4 | 09-17-2008 04:27 PM |
