Old 03-12-2009, 07:01 PM
vEsotu vEsotu is offline
Loading morph mesh error.
I recently tried to load a 3DSMax mesh for my morph of a person gaining weight and losing weight. Before hand, I was able to use the morph just fine. Now, I get this error, and I'm not sure if there's been any documentation somewhere that I can look at to resolve it.
cal3d : Internal error in .\coremesh.cpp(160)
** WARNING: Failed to load morph file: sportive02_f_mesh_fat.CMF
If possible, how can I fix this? And what is causing this error?
Thanks!
Old 03-13-2009, 10:13 AM
This error means that the number of vertices in the morph mesh does not match the number of vertices in the base mesh. You need to ensure that both meshes have the same number of vertices.
Old 03-14-2009, 06:29 PM
Ah, that seemed to do the trick! Thanks!
Problems loading WRL file DrunkenBrit Vizard 2 01-29-2009 12:58 AM
Error loading plugin djdesmangles Vizard 2 10-02-2008 07:13 AM
Error when loading a lot of avatars dan12345 Vizard 7 07-28-2008 04:24 AM
Multiple Mesh Avatar Texturing v-jbinney Vizard 6 11-13-2007 11:00 AM
The error window that couldn't FlyingWren Vizard 2 12-02-2003 08:23 AM
