Old 08-28-2008, 02:34 PM
whj whj is offline
animation question
hi,
I'm trying to create an animation of a moving car. Animation path seems to be a handy way. But I also want to change the speed of the car or even stop the car when some event occurs. I don't see any control of speed is available to the animation path. Does anyone have an idea how to do it?
Thanks a lot.
whj
Old 08-28-2008, 04:31 PM
With animation paths you can change the speed of the animation or you can pause an animation. To reduce the speed by half
path = viz.add(viz.ANIMATION_PATH)
path.speed(.5)
to pause the animation
path.pause()
Old 08-29-2008, 03:01 PM
whj whj is offline
Thank you.
Old 09-05-2008, 10:16 AM
whj whj is offline
Hi, I have another question on animation path.
When I use path.autorotate(), all my cars move along their current trajectory, which is great. But some of them move forward, and some of them move backward. I don't know how to control the rotation of the objects when I use animation path. The following is my code:
mybus = viz.add('schoolbus.3ds')
positions = [ [-40,1.25,-4], [-30,1.25,-3], [-20,1.25,-2], [-10,1.25,-6], [0,1.25,-30], [10,1.25,-10], [20,1.25,7], [30,1.25,-10], [50,1.25,2] ]
for x in range(0,len(positions)):
cp = viz.add(viz.CONTROL_POINT)
cp.setPosition(positions[x])
path.add(cp,x+1)
path.constantspeed(viz.ON,CAR_SPEED)
path.loop(viz.LOOP)
path.translatemode(viz.BEZIER)
path.setAutoRotate(viz.ON)
mybus.link(path)
path.play()
Old 09-08-2008, 09:21 AM
Since there is a link between the animation path and the car you can offset the car's position or orientation from the path's. If I understand correctly you want to offset the orientation so that the car is facing the opposite direction. Here is some code that takes 2 wheelbarrows and animates them along a path. The second wheelbarrow will get rotated so it faces the opposite direction. Then its position is offset slighty from the path so it appears below the first one. Let me know if that helps.
wheel1 = viz.add('wheelbarrow.ive')
wheel2 = viz.add('wheelbarrow.ive')
positions = [[0,0,10],[5,0,10],[5,0,15],[0,0,15]]
	path.add(cp,x+1)
path.constantspeed(viz.ON,1)
path.loop(viz.LOOP)
#link the first wheelbarrow to the path
wheel1.link(path)
#link the second wheelbarrow to the path then
#offset the wheelbarrow's orientation so it is opposite the path
#and offset its position from the path so it will be
#below the first wheelbarrow
wheel2link = viz.link(path, wheel2)
wheel2link.preEuler([180,0,0])
wheel2link.preTrans([0,-1,0])
path.play()
Old 09-08-2008, 12:13 PM
whj whj is offline
Thank you, Jeff. That works very well.
General question and question regarding arrays dan12345 Vizard 1 01-15-2008 10:15 AM
Animation Tracks.... k_iwan Vizard 2 03-26-2007 05:52 PM
Jumpy animation Elizabeth S Vizard 1 11-08-2006 02:11 PM
avatar animation problems jrodman Vizard 1 01-18-2006 09:12 AM
to rephrase my question... shai Vizard 2 10-27-2004 10:55 AM
