Problems with newest version of Vizard
Hello. The newest version of Vizard does not work for me. The first thing that happens is the primary output of my monitor gets switched. Then I get these errors:
Starting study:2008-07-14 14:49:50 intersense.dls Intersense Driver v2.1 Could not load isense ISD_GetTrackerConfig failed ** ERROR: Intersense device has no active stations vizppt.dls WorldViz PPT v3.0 PPT: cannot open serial port: No such file or directory ** ERROR: Failed to connect to PPT vizppt.dls WorldViz PPT v3.0 PPT: cannot open serial port: No such file or directory ** ERROR: Failed to connect to PPT |
Are you using version 3.10.0030 ? The original quarterly release (3.10.0028) contained the latest drivers from InterSense, which we have since found to be unstable. The newest release, available on our website, uses the last known stable InterSense driver.
Even after rolling back ppt did not work. To make it work I now have to write in every script: PORT_PPT = 1 Is there any global vizard file we can add the PORT_PPT = 1 command to instead of adding it to all our scripts? |
We are also experiencing the same problem
Changing to the newest version of vizard, stopped the interesense from working... We still haven't rolled back to the previous version... Would be very happy for a quick fix!!
Thanks, dan |
Did it also switch the primary ports on your machine?
I'm concerned now about any future updates...can we not use them since clearly the new drivers are unstable on our system?
Vizard does not automatically install any updates on your system, it is up to you to download and install them. If an older version of Vizard is working fine for you, then you can use it as long as you want.
Similar Threads | ||||
Monitor Modes & Vizard (problems...) | tmcw | Vizard | 1 | 10-03-2007 07:29 AM |
face problems in Vizard 3.0 | v-clizzin | Vizard | 2 | 09-19-2007 03:32 PM |
euler problems in Vizard 3.0 | v-clizzin | Vizard | 3 | 08-16-2007 06:10 PM |
Export/import problems and Vizard 3.0 release | searsky | Vizard | 0 | 01-03-2006 01:34 AM |
Next version of Vizard | bailenson | Vizard | 1 | 08-04-2004 05:45 PM |
