Old 04-25-2008, 10:03 AM
aznan aznan is offline
Same texture, but different..
I want to have a model with one texture that can be swapped with another using model.texture("new_tex.jpg"). When swapping back I noticed that the new "first" texture was much darker than the original.
I have attached a scene with two cubes which demonstrates the problem.
What is happening?
Old 04-28-2008, 10:39 AM
I tried adding a cube without any textures, thinking maybe the original texture blended with the new original, but then it turned completely black. I also tried playing around with model.appearance() and texblend, but to no avail.
Doesn't anyone have a clue as to what is going on?
Old 04-28-2008, 10:51 AM
The cube uses negative values for the texture coordinates. This means you need to enable wrapping on the texture. Try using the following code when adding the texture:
tex = viz.addTexture("red2.gif",wrap=viz.REPEAT)
Vizards default wrap mode is viz.CLAMP_TO_EDGE, which does not allow for texture coordinates outside the range of [0,1].
Old 04-29-2008, 02:29 AM
Yup, that was it. Thanks a bunch!
3D Texture Mapping in Vizard? stefs Vizard 2 03-25-2008 03:34 AM
missing parts of head texture sjp Vizard 4 10-10-2006 01:10 PM
how I can get my texture to appear exactly as is defined mspusch Vizard 1 04-23-2005 12:12 PM
avatar head texture issues rconrey Vizard 3 11-17-2004 04:05 PM
How to simply texture an avatar's head with a jpeg graphic? vr_boyko Vizard 3 10-26-2004 10:44 AM
