Old 11-28-2006, 02:21 PM
giancamati giancamati is offline
Smile 3D cursor with FlockOfBirds
Good Morning,
I am developing a 3D virtual environment in which I tracker my hands with flock of birds devices. Now, with the Vanda I would like to implement a 3D cursor. I visualize my 3D cursor as a sphere and I would like to understand if there is a way to fast determine in my sphere intersects an object in the scene. If there is an intersection I pick the object up and move, otherwise nothing happens.
Thank you so much.
Giancarlo
Old 12-06-2006, 04:07 PM
Here is a sample script that does what you want. It uses physics shapes to check if models are colliding. If they are, it sets up a "grab" link between the models.
viz.clearcolor(viz.SKYBLUE)
viz.MainView.setPosition([0,0,-3])
viz.phys.enable()
logo = viz.add('logo.wrl', pos=[1,0,0])
logo.collideMesh()
marker = viz.add('marker.wrl', pos=[-1,0,0])
marker.collideMesh()
duck = viz.add('duck.cfg', pos=[0,1,0])
duck.collideMesh()
#Add the object that will do the grabbing
hand = viz.add( 'hand.cfg' )
hand.setScale([3,3,3])
hand.translate( 0, 0, 0 )
hand.collideMesh()
grabLink = None #The handle to the link object
#Grab or let go of the ball
def tryGrab():
	global grabLink
	nodes = viz.phys.intersectNode(hand)
	if len(nodes) > 0: #if list is not empty
		grabLink = viz.grab( hand, nodes[0] )
def drop():
	global grabLink
	grabLink.remove()
	grabLink = None
def grabOrDrop():
	if grabLink:
		drop()
		tryGrab()
vizact.onkeydown(' ',grabOrDrop)
#Setup keyboard control of hand
vizact.whilekeydown(viz.KEY_UP,hand.translate,0,vizact.elapsed(1),0,viz.RELATIVE_WORLD)
vizact.whilekeydown(viz.KEY_DOWN,hand.translate,0,vizact.elapsed(-1),0,viz.RELATIVE_WORLD)
vizact.whilekeydown(viz.KEY_RIGHT,hand.translate,vizact.elapsed(1),0,0,viz.RELATIVE_WORLD)
vizact.whilekeydown(viz.KEY_LEFT,hand.translate,vizact.elapsed(-1),0,0,viz.RELATIVE_WORLD)
vizact.whilekeydown('w',hand.rotate,1,0,0,vizact.elapsed(90),viz.RELATIVE_WORLD)
vizact.whilekeydown('s',hand.rotate,1,0,0,vizact.elapsed(-90),viz.RELATIVE_WORLD)
vizact.whilekeydown('d',hand.rotate,0,1,0,vizact.elapsed(90),viz.RELATIVE_WORLD)
vizact.whilekeydown('a',hand.rotate,0,1,0,vizact.elapsed(-90),viz.RELATIVE_WORLD)
File Type: zip selectingWithPhysicsShapes.zip (746 Bytes, 1134 views)
Paul Elliott
WorldViz LLC
Old 12-07-2006, 09:10 AM
great
Thank you so much it works fine!.
