error when using head morph
I have an intermittent error when using a simple blink function for an avatar. This is what the error is reported as: Traceback (most recent call last): File "the final version (fixing the bugs).py", line 712, in Blink4 person4.head.morph(0,0,.1) File "C:\Program Files\Vizard25\viz.py", line 3509, in morph self.add(morphAction,thread) File "C:\Program Files\Vizard25\viz.py", line 2997, in add self._action.addAction(what,*args) File "C:\Program Files\Vizard25\viz.py", line 5854, in addAction self.actionPool[thread].actionList.append([action,get(CLUSTER_MASK)]) KeyError: -600 Here is the blink5() function, which is passed to viz.director(): Code:
def Blink4(): global person4 person4.head.morph(0,1.0,.1) viz.waittime(.15) person4.head.morph(0,0,.1)] I've noticed a similar problem when using avatar actions: after the action is completed, Vizard often does not return to the idling action, but instead reports a bug because it cannot randomly choose which idle action to randomly return to. Anyway, if anyone has seen this problem and can suggest a solution, or what might be causing it, that would be great. I'm sure this has been fixed for Vizard 3, so any quick fix would suffice. Thanks, -Ben Last edited by Vbents; 08-10-2006 at 11:35 AM. |
Don't really know what is causing this problem. I agree that the problem probably lies with the state of the avatar's action pool.
Because it is intermitant, I suspect that it could be caused by your use of viz.director. Director functions are like threads. Perhaps using the vizact.waittime() action instead of the director function would fix things.
Paul Elliott WorldViz LLC |
