Old 11-28-2017, 12:28 AM
bbb bbb is offline
Problem with vizconnect
Hi Jeff,
I have a problem with and i wanted to upload my vizconnect files but there is a problem with the file's size and type, attached is a google drive shared link with the files https://drive.google.com/drive/folders/1ie9URLXV5kM9aiw0znwyQF12sYdN4fNQ?usp=sharing
I have an environment in which participants are using xbox one controller for navigation (left joystick for turning left and right, right joystick for walking forward, backward, left and right) with Oculus Rift DK2 (named new).
I want them to get to a target location and when they do so, i want that they were only able to turn around with the left joystick but won't be able to walk with the right joystick. Using vizconnect.getTransport('main transport').setEmabled(viz.OFF) or something similar causes for not moving or turning with the xbox at all but only allow for movement according the googles (Oculus Rift). How can i overcome this issue?
I used your Oculus Rift with mouse and keyboard preset in the vizconnect and changed the file inside in order for having synchornized movements of orientation from the googles according to the position, so i have to use this preset (in another vizconnect file named old, , the vizconnect.getTransport('walking').setEmabled(viz. OFF) solved the problem i described).
I tried to add another transport and mimic what i did with the first file but failed to achive the same thing.
Thanks in advance.
Old 11-28-2017, 01:35 AM
You could break up the position/orientation movements into two transports that are linked together using a transportation group. At the target location, disable just the transport that controls the user's position. Attached is a desktop example.
3D monitor display with Vizconnect rdkirkden Vizard 2 09-14-2017 02:17 AM
Switching between input devices setup in vizconnect and not using vizconnect JB_HP_Viz Vizard 1 01-20-2015 05:19 AM
Vizconnect SpaceGrip problem JB_HP_Viz Vizard 3 06-17-2014 03:03 AM
Vizconnect Save As Dialog Jeff Vizard 0 05-01-2014 09:45 AM
