Old 01-14-2016, 10:54 AM
pitbool pitbool is offline
osgb model displayed in inspector not showing up in script
We have an osgb model in which we have customized some animations from 3DS max. The file size is 733 MB.
We can view this file in the inspector, but it is not loading up in the simplest possible vizard script below:
#viz.add('piazza.osgb')
viz.add('Zone3_FishTest1.osgb')
Any thoughts on what might be the problem?
Thank you.
Old 01-15-2016, 06:19 AM
What kind of graphics card do you have in this machine?
Old 01-19-2016, 11:04 AM
Jeff, It appears that our team has found some kind of a workaround, at least temporarily. Let me bug you again if we hit another wall.
Thank you for your help!
Old 02-09-2016, 11:27 AM
A quick update - just realized yesterday that the original problem might have been due to exporting from 3DS max with non-meter units (this can be controlled from a dropdown in the final section of the export pop-up).
Blank screen on external monitor when running a Vizard script with Oculus DK2 mstan Vizard 4 09-03-2015 05:58 AM
3ds Exported .IVE Model mirrors movement of Mainview Felix Vizard 9 05-18-2012 09:17 AM
Change model alpha and memory leak hosier Vizard 2 06-25-2009 10:55 AM
