Old 09-26-2011, 03:01 PM
Kaminski Kaminski is offline
Spin Pivot with a WRL
Hey all,
I am experiencing some difficulty getting a model to spin around a pivot (I am trying to get a door to open and close). Is it possible to set the pivot in 3ds Max and then export as a WRL? This KB article explains how to do it with an IVE file, but my version of 3ds max seems to export a newer file than the vizard 3.0 OSG library can handle.
I can't seem to recover the pivot point that I set for the door in 3ds max. Any advice?
Old 09-27-2011, 11:03 AM
Can you post an example WRL file and the code you are using to spin the door?
If the door node is contained in a hierarchy, then you might be getting a handle to the wrong node. For example, if the WRL file is creating a transform above the door to offset the pivot, then you will need to get a handle to the transform in order to spin the door about the pivot.
easeIn for a spin? chris_user Vizard 2 06-14-2011 07:04 AM
Changing pivot center midway through animation vijaykiran Vizard 2 10-19-2009 10:10 AM
spin around axis object kazo11 Vizard 2 04-19-2007 09:48 AM
Pivot points for child objects in Vizard with 3ds Max Gladsomebeast Vizard 0 09-19-2006 11:21 AM
Spin Move oscar Vizard 2 12-03-2004 05:52 AM
