Old 10-10-2016, 05:17 AM
shashkes shashkes is offline
how to make the viz.connect avater invisible?
Hi, for an experiment I'm running I want the avatar that is created using viz.connect and optotrak sensors and representing the subjects movements to become invisible for some of the trials and visible again for others.
I don't want to remove the avatar because I still want to register the location of the sensors I just want the avatar not to appear on the screen so on some trials the subject gets visual feedback of their movements while on others not.
what is the best way to do that?
Thanks!
Old 10-10-2016, 05:33 AM
Use the vizconnect avatar's setVisible method. It can be set to viz.ON, viz.OFF, or viz.TOGGLE:
avatar = vizconnect.getAvatar('male_2')
avatar.setVisible(viz.OFF)
Old 10-10-2016, 08:04 AM
That didn't work for me. I had to use the getNode3d(), which turned out to be viz.VizAvatar(13). so this worked:
subjectavatar = vizconnect.getAvatar()
print str(subjectavatar.getNode3d())
viz.VizAvatar(13).visible(viz.OFF)
Old 10-10-2016, 08:07 AM
oh, I realized if I use male not male_2 avatar so your solution also works if I remove the 2thanks
avatar = vizconnect.getAvatar('male')
avatar, visability, vizconnect
How to make neck of avatar invisible Frank Verberne Vizard 4 02-05-2014 05:39 AM
How to make character animation sequence wchoi Vizard 3 01-22-2010 08:35 AM
Invisible haptic objects Haptiken Vizard 1 05-05-2009 04:04 PM
