Old 05-18-2010, 02:12 AM
ruby21 ruby21 is offline
problems nagivating around
hi..im very new to vizard and i just want to simply nagivate around a building.ive managed move forward and backwards..but having problems moving right and left by keyboard.
heres the code that im using..could anyone tel me if the code is right or am i missing something out.i'd appreciate the help..thanks...
myView
myView = viz.get(viz.MAIN_VIEWPOINT)
def moveTimer(num):
if viz.iskeydown('a'):
myView.move (0,0,1)
if viz.iskeydown('z'):
myView.move (0,0,-1)
viz.callback(viz.TIMER_EVENT,moveTimer)
viz.starttimer(1,0.05,viz.FOREVER)
TURN = 25
def mytimer():
if viz.iskeydown(viz.KEY_RIGHT):
view.rotate(0,1,0,TURN*viz.elapsed(),viz.BODY_ORI, viz.REL_PARENT)
if viz.iskeydown(viz.KEY_LEFT):
view.rotate(0,1,0,-TURN*viz.elapsed(),viz.BODY_ORI,viz.REL_PARENT)
vizact.ontimer(0,0,1, mytimer)
Old 05-18-2010, 06:36 AM
Darkmax Darkmax is offline
please use the code tags when your are going to post code, because indentation is very important in python.
And for your navigation problem try this code:
viz.add("lab.ive")
myView = viz.MainView
TURN = 25
SPEED = 0.1
def moveView():
		myView.move (0,0,SPEED)
		myView.move (0,0,-SPEED)
		myView.rotate(0,1,0,TURN*viz.elapsed(),viz.BODY_ORI, viz.REL_PARENT)
		myView.rotate(0,1,0,-TURN*viz.elapsed(),viz.BODY_ORI,viz.REL_PARENT)
vizact.ontimer(0,moveView)
Old 05-18-2010, 03:22 PM
thanks mater..really appreciated that..it works..once again thank you and sorry that wont happen again i will make sure i use the code tags
Problems creating a mirror Josh Vizard 2 01-28-2010 12:21 PM
Problems loading WRL file DrunkenBrit Vizard 2 01-29-2009 12:58 AM
2 problems with our HMD Vbents Precision Position Tracker (PPT) 1 07-26-2006 07:55 PM
Viz PPT 1 problems Adam Precision Position Tracker (PPT) 3 08-30-2005 10:51 AM
Problems with lighting in 2.0 murm Vizard 6 04-21-2004 09:59 AM
