Old 02-02-2011, 12:55 AM
vEsotu vEsotu is offline
Phantom, Vizard 3.0, OpenHaptics 3.0
I'm currently working on a follow up study for the code in this post:
http://forum.worldviz.com/showthread.php?t=1134
And I'm getting the following error in which Vizard is failing to load my plug-in:
** ERROR: Failed to load plug-in: 'hd.dlm'
File "<string>", line 11, in ?
File "MOF_Colorblind_Version16_Subject.py", line 211, in ?
hd_obj = hd.get(hd.TOUCH_OBJECT) # object that the haptic device is dragging
File "C:\Program Files\WorldViz\Vizard30\python\hd.py", line 231, in get
return _gettouchobject_(0)
File "C:\Program Files\WorldViz\Vizard30\python\hd.py", line 215, in _gettouchobject_
touchID = _hd_.get()[0]
IndexError: list index out of range
I went through several tests with loading "hd.dlm" and "hd2.dlm" (I also made sure they were in the plug-ins folder under Vizard 3.0.
In addition, I've tried numerous times reinstalling the OpenHaptics 3.0 and PDD drivers. For some reason, I am able to run my code on a personal laptop (which has Vizard 3.0 and OpenHaptics 3.0 on a Windows 7 32-bit system), but I cannot run the same code on a lab computer (which has Vizard 3.0 and OpenHaptics 3.0 on a Windows 7 64-bit system).
I know the Haptic Device is plugged in and working because it runs through the Phantom Configuration and Test programs just fine.
So, I was wondering if maybe Vizard does not support OpenHaptics 3.0 on a 64 bit system or if there is some other low-level magic I am unaware of that may be causing Vizard's failure to read the plug-in?
I'd appreciate any help you can provide!
Thanks in advance!
Old 02-02-2011, 10:12 AM
The Vizard SensAble plug-in was built using OpenHaptics 2.0, so it will not work with OpenHaptics 3.0.
Old 02-02-2011, 09:04 PM
Thanks for the clarification, Farshizzo.
I'm still perplexed by the situation then. As I said before, the code runs smoothly on my personal laptop (no errors in locating the "hd.dlm" file), but when I run on my lab's desktop (which has a similar set up to my laptop) Vizard cannot detect the hd.dlm file.
The only differences I can note from both setups include the following:
Laptop:
32-bit Windows 7 system
Lite-Edition of Vizard 3.0
Visual Studio 2010
Desktop:
64-bit Windows 7 system
Trial version of Developer's edition of Vizard 3.0
Visual Studio 2005 (seems necessary to have according to the OpenHaptics support section on Sensable's site)
Is there anything else I might want to look into more to determine a solution to this issue? Or is there any other kind of information I can provide you to help me detect the hd.dlm file?
.3DS importing in Vizard and 3D Studio jde Vizard 1 08-28-2009 03:14 PM
SenseAble Phantom set up with Vizard jfreeman Vizard 1 06-01-2005 10:27 AM
