Old 09-01-2008, 01:39 AM
luakt luakt is offline
Software to create animated characters
I am new to Worldviz. Can some one tell me what are the best software to generate animated characters to be used with Worldviz. I find 3dsmax too expensive. Thanks
Old 09-05-2008, 08:55 PM
3DS Max is our default recommendation as it's by far the most professional workflow. But it is costly both in terms of purchase price and the learning curve. There are free 3D modeling programs such as Blender and Milkshape that support export into the Cal3D format (what Vizard uses) but we're not familiar with the workflow and I honestly doubt it's much simpler than the 3DS Max method and probably less robust, albeit cheaper. Vizard also has good support for Collada, and I know Collada supports deformable mesh objects like avatars, so if you know some good content creation tools that can export Collada, perhaps that's a solution.
Old 09-12-2008, 12:09 AM
Can we use POSER Pro for character animation?
PROSER pro supports callada export.
Can we use this software to generate avatars for WorldViz?
Old 09-14-2008, 11:01 PM
tobin tobin is offline
I do not believe Poser direct exports into Cal3D. You can import the Poser content into 3DS Max, and then export to Cal3D from 3DS Max.
Live Characters plugin Frank Verberne Vizard 7 03-01-2012 02:23 AM
How to create a sky? guxmy01 Vizard 1 05-28-2008 12:07 PM
Complete Characters and 3dmax dan12345 Vizard 3 02-07-2008 06:32 PM
how to create morph from the comple characters CD michelcm3 Vizard 9 07-19-2007 10:15 AM
animated gifs jrodman Vizard 1 03-16-2004 09:48 AM
