Number Pad input
Hi all,
I'm hoping that someone knows how to get vizact.onkeydown to recognize a number pad input. For example, if I enter: Code:
vizact.onkeydown('0',myFunction) I ask because I've created a simple response time task using vizard which tracks the workload of subjects in a behavioral study. There is limited space in the environment where the study is being run, and a small USB number pad is a pretty good input device that takes up very little space. |
Try using key codes instead of numbers to get the number pad key events:
def printKey(key): print key vizact.onkeydown(viz.KEY_KP_0,printKey,'KP_0') vizact.onkeydown(viz.KEY_KP_1,printKey,'KP_1') vizact.onkeydown(viz.KEY_KP_2,printKey,'KP_2') vizact.onkeydown(viz.KEY_KP_3,printKey,'KP_3') |
Thread Tools | |
Display Modes | Rate This Thread |
Regarding Flystick2 not detected in Vizconnect as an input | rajnishv | Vizard | 2 | 11-28-2016 03:08 AM |
Switching between input devices setup in vizconnect and not using vizconnect | JB_HP_Viz | Vizard | 1 | 01-20-2015 05:19 AM |
Blindfolding screen, asking for input, unblindfolding. | saajaja | Vizard | 5 | 11-14-2013 08:08 AM |
does vizard handle input differently when it's embedded? | Adam.Grey | Vizard | 3 | 06-28-2012 09:07 AM |
problem with input boxes | shai | Vizard | 6 | 08-15-2005 10:51 AM |
