Old 11-06-2015, 09:31 AM
chris2307 chris2307 is offline
Positioning text with ORTHO parent
I am trying to display some text on a black screen in Vizard. On single screen applications, this is very easy; I just turn the world off and display my text with the screen as the parent, i.e.:
text1 = viz.addText(txt, parent=viz.SCREEN)
My problem is when I create a three-screen application. To do so, I am creating three viz.WINDOW objects and offsetting the left and right windows by +/- 60-deg. I have to set the parent to viz.ORTHO if I wish to see text on these windows. However, they are being positioned to the default location of the bottom left of the specified window which is not where I want to see them.
text1 = viz.addText(txt, parent=viz.SCREEN, parent=viz.ORTHO, scene = screen.leftWindow)
The setPosition() function no longer works so I'm not really sure what I need to be doing in order to correctly position the text relative to the window.
Old 11-06-2015, 12:42 PM
You can specify pixel coordinates or link to a window location:
#set position in pixel coordinates
text1 = viz.addText('text1',parent=viz.ORTHO)
text1.setScale([100,100,0])
text1.setPosition([300,200,0])
#link to center top
text2 = viz.addText('text2',parent=viz.ORTHO)
text2.setScale([100,100,0])
text2.alignment(viz.ALIGN_CENTER_TOP)
viz.link(viz.CenterTop,text2)
#link to upper left with offset
text3 = viz.addText('text3',parent=viz.ORTHO)
text3.setScale([100,100,0])
text3.alignment(viz.ALIGN_LEFT_TOP)
link = viz.link(viz.LeftTop,text3)
link.setOffset([20,-20,0])
Old 11-07-2015, 05:59 AM
Ah!
It was pixel coordinates. I was attempting to use the same normalised screen units that worked when I was using viz.SCREEN as the parent so this makes much more sense now.
Displaying screen text in 3D (Oculus Rift) pjayaram Vizard 2 05-27-2014 08:06 PM
input from a text file dig Vizard 5 10-20-2013 01:20 AM
Informationboxes with text snoopy78 Vizard 3 07-16-2009 10:23 AM
3d Text with Transparent Borders vjosh Vizard 3 12-01-2004 10:50 AM
