Old 07-10-2013, 05:50 AM
javadi javadi is offline
Unexpected Change of Window Size
Dear all
I have two problems with window size that might be related to each other. First of all, the window size is not what I define. I define the window size as
viz.window.setSize([WindowWidth, WindowHeigh])
When I run only these two lines Vizard opens a window with correct size, but when I run the whole code, it creates a window with wrong size. I also tried to open a full screen window using the following code but was not successful.
viz.go(viz.FULLSCREEN)
The 2nd problem is unexpected change in window size. After a few seconds of running the presentation, the size of the window changes to a narrower window (smaller height). It causes misalignment of some of the textures in the screen.
I run the code on Vizard 4.08. I should add that I have absolutely no problem with the same code on a different machine with Vizard 4.05.
What could be causing these problems? Very many thanks.
Greetings
Amir
Old 07-10-2013, 09:26 AM
Do you have a trial or lite license of Vizard? If so, they only support fullscreen mode for 10 seconds and will automatically resize afterwards.
Old 07-10-2013, 09:50 AM
Thanks for your reply. We have lite license. We normally don't use full screen anyway. I used it once to check whether it works or not, after facing those problems.
Cheers
Amir
Old 07-19-2013, 03:53 AM
Cheers
Amir
Hi farshizzo and all
May I remind about this post? Still, I've not found out how to deal with this unexpected resizing issue. Very many thanks.
Greetings
Amir
Old 07-19-2013, 10:41 AM
That is the expected behavior for the Lite license. It supports fullscreen mode for 10 seconds and then will automatically resize.
Old 07-19-2013, 03:45 PM
Hi Jeff
Very many thanks for your reply. But we don't use full screen at all. We define the size of the screen explicitly as follows
viz.window.setSize([640, 480])
Vizard even doesn't open the screen with correct size. For instance the size of the opened window for the defined size of 320 x 240 is quite the same as the size 640 x 480.
Thanks for your time and attention. We highly appreciate your help.
Greetings
Amir
Old 07-23-2013, 10:40 AM
The lite license will limit the window size to 3/4 the resolution of the screen.
Old 07-23-2013, 02:56 PM
Main window size larger than monitor dpamplona Vizard 2 01-25-2012 01:55 PM
Can I change the text size of slider object? jincheker Vizard 1 08-26-2011 11:20 AM
Possible to change size of a vizshape.addBox object? Renato Lima Vizard 1 10-18-2010 09:51 AM
How to change the size of different parts of an avatar? llqqff Vizard 3 02-23-2010 04:16 PM
