Old 03-23-2013, 04:30 AM
goro goro is offline
Multi-Pass Rendering
It is written in Vizard's Core Features under Technical Features that Vizard supprots multi-pass & multi-stage rendering. I am working on Augmented Reality & multi passing is essential for us to get realistic output.
By using <viz>.addRenderTexture() command I am able to get the screen output. By using shaders I can even process that texture. But my requirement is to process the processed textures.
Input_Texture --- > Pass 1 ------> Output 1
Input_Texture --- > Pass 2 ------> Output 2
Input_Texture --- > Pass n ------> Output n
{Output 1, Output 2, .... , Output n} --- > Final Pass ----> Final Output
Please help me with the solution. If I am conceptually wrong then please correct me.
Thanks!
Old 03-28-2013, 04:55 AM
To elaborate my question, I am explaining this with code:
viz.add('piazza.osgb')
# Add render texture using depth pixel format
img = viz.addRenderTexture()
# Use render node to render the scene to the depth texture
rn1 = viz.addRenderNode()
rn1.setRenderTexture(img)
rn1.setEuler(180,0,0)
rn2 = viz.addRenderNode()
rn2.setRenderTexture(img)
rn2.setEuler(180,0,0)
# Display depth texture on the screen
quad1 = viz.addTexQuad()
quad1.setScale(3,2)
quad1.setPosition(-2,2,6)
quad2 = viz.addTexQuad()
quad2.setScale(3,2)
quad2.setPosition(2,2,6)
# Use shader to display depth texture in linear range
fragSepia = """
uniform sampler2D InputTex;
		void main()
			vec4 color = texture2D(InputTex,gl_TexCoord[0].st);
			gl_FragColor.r = dot(color.rgb, vec3(.393, .769, .189));
			gl_FragColor.g = dot(color.rgb, vec3(.349, .686, .168));
			gl_FragColor.b = dot(color.rgb, vec3(.272, .534, .131));
			gl_FragColor.a = color.a;
fragGray = """
		void main()
			float lum = 0.222*color.r + 0.707*color.g + 0.071*color.b;
			gl_FragColor = vec4(lum,lum,lum,color.a);
shader = viz.addShader(frag=fragSepia)
quad1.apply(viz.addUniformInt('InputTex',0))
quad1.apply(shader)
quad1.texture(img)
shader2 = viz.addShader(frag=fragGray)
quad2.apply(viz.addUniformInt('InputTex',0))
quad2.apply(shader2)
quad2.texture(img)
# Need to specify clip plane here and in shader
viz.clip(0.1,200)
This code gives me output as follow:
Left Side is Sepia Effect & Right Side is Gray Effect. I want to produce third effect i.e. 70% Sepia & 30% Gray. I am willing to use Multi-Passing & everything should be behind the screen & main window should have the final output.
Thanks!
Old 03-29-2013, 12:03 PM
Just to be clear, are you wanting to apply the shader to the entire screen, or just to a single object within the world?
Old 03-30-2013, 01:17 AM
I am planning to apply the shader to the entire screen just like vfx guys do.
In our project of Augmented Reality, the CG quality is very superior than the HD webcam generated Image. So the image & cg are not going together. Our vfx guy suggested us that we have to separately make CG blur and add some post rendered effects on it; we have to separately enhance the image quality of Webcam output and then marge both.
Old 04-02-2013, 12:04 AM
Hello all! We have developed further of our own and found one solution. We are sharing the code with you.
#Adding Models to two different scenes
piazza = viz.addChild('piazza.osgb',viz.WORLD,2)
pit = viz.addChild('pit.osgb',viz.WORLD,3)
#Creating render node & adding Render Texture for Scene 2
video1 = viz.addRenderTexture()
cam1 = viz.addRenderNode(size=(1280,720))
cam1.setScene(2)
cam1.setFov(60.0,1280/720.0,0.1,1000.0)
cam1.attachTexture(video1)
cam1.setRenderLimit(viz.RENDER_LIMIT_FRAME)
#Creating render node & adding Render Texture for Scene 3
video2 = viz.addRenderTexture()
cam2 = viz.addRenderNode(size=(1280,720))
cam2.setScene(3)
cam2.setFov(60.0,1280/720.0,0.1,1000.0)
cam2.attachTexture(video2)
cam2.setRenderLimit(viz.RENDER_LIMIT_FRAME)
# Adding quad to Main Scene & scaling & positioning it to occupy whole screen
quad = viz.addTexQuad(viz.WORLD,1)
quad.setPosition(0,1.8,4.1)
quad.setScale(4,3)
#Applying textures from outputs of Scene2 & Scene3
quad.texture(video1,unit = 0)
quad.texture(video2,unit = 1)
viz.scene(1) # Setting Scene 1 as main scene
#Applying post process shaders to Render Nodes
#------------- Post Process Effects on Scene2--------------------#
fragCode = """
		void main()
SepiaEffectShader = viz.addShader(frag = fragCode)
ui_inputTex = viz.addUniformInt('InputTex',0)
cam1.apply(SepiaEffectShader)
cam1.apply(ui_inputTex)
#------------- Post Process Effects on Scene3--------------------#
fragCode = """
		uniform sampler2D vizpp_InputTex;
		void main()
			vec4 color = texture2D(vizpp_InputTex,gl_TexCoord[0].st);
			gl_FragColor = vec4(1.0-color.r,1.0-color.g,1.0-color.b,1);
InvertColorShader = viz.addShader(frag = fragCode)
cam2.apply(InvertColorShader)
cam2.apply(ui_inputTex)
#Applying Final Blending on quad
#------------------- Final Texure blend Effect -----------------------------#
VertCode = """
		void main()
			gl_Position = ftransform();
			gl_TexCoord[0] = gl_MultiTexCoord0;
FragCode = """
		uniform sampler2D tex1;
		uniform sampler2D tex2;
		void main(void)
			vec4 texture1 = texture2D(tex1,gl_TexCoord[0].st);
			vec4 texture2 = texture2D(tex2,gl_TexCoord[0].st);
		   gl_FragColor = texture1* texture2;
BlendShader = viz.addShader(vert = VertCode,frag = FragCode)
ui_tex1 = viz.addUniformInt('tex1',0)
ui_tex2 = viz.addUniformInt('tex2',1)
quad.apply(BlendShader)
quad.apply(ui_tex1)
quad.apply(ui_tex2)
#Locking mouse navigation as quad is 2D & objective is Augmented Reality & Not Virtual Reality
viz.mouse(viz.OFF)
And the output is:
We are getting the desired result. Our question is, is there any other much appropriate method or much optimized method to get the same?
Old 04-05-2013, 02:13 AM
We are sticking to same logic as above. We have wrote a code using the same logic which is discussed above. This program is working fine as no shader is applied. The program is as below:
#Adding WebCam
video = viz.add('VideoCamera.dle')
cam = video.addWebcam()
#Adding & setting quad to Scene 1
quad1 = viz.addTexQuad(viz.WORLD,1)
quad1.setScale(2,1.5)
quad1.setPosition(0,1.8,2)
#linking quad to MainView to get Constant 3D
link = viz.link(viz.MainView,quad1)
link.preTrans([0,0,2])
#Adding piazza environment to Scene2
#Adding & setting quad to Scene 2
quad2 = viz.addTexQuad(viz.WORLD,2)
quad2.setScale(2,1.5)
quad2.setPosition(0,2,6)
quad2.texture(cam)
#Adding Render Texture to Scene2 & setting it as a Texture to quad1
CamScene = viz.addRenderTexture()
quad1.texture(CamScene)
#Adding Render Node in Scene2
rn = viz.addRenderNode(size=(1280,720))
rn.setScene(2)
rn.setFov(60.0,1280/720.0,0.1,1000.0)
rn.attachTexture(CamScene)
rn.setRenderLimit(viz.RENDER_LIMIT_FRAME)
viz.scene(1)
The output is as below:
The center quad is webcam image.
But when we add shader program to the above code
InvFragCode = """
		void main()
InvShader = viz.addShader(frag = InvFragCode)
rn.apply(InvShader)
rn.apply(viz.addUniformInt('InputTex',0))
it works well for the rest of the environment but the webcam image gets blackout as below:
We don't know why this is happening?! Please help us to solve this issue..
Thanks!
Old 04-05-2013, 11:37 AM
Your code is applying the shader to all objects in the scene. It seems like you should be applying the shader to the quad that is rendering the rendered texture instead:
quad1.apply(InvShader)
Also, you might want to consider using the vizfx.postprocess library. For example, here is your script converted to use the library with the built-in inverse color effect applied:
#Adding WebCam
piazza = viz.addChild('piazza.osgb')
quad2.texture(cam)
#Apply inverse post-process effect
import vizfx.postprocess
from vizfx.postprocess.color import InvertColorEffect
vizfx.postprocess.addEffect(InvertColorEffect())
Old 04-05-2013, 10:10 PM
Render Node is a node; so my assumption was, we can apply shader to Render Node. Please correct me if I am wrong. We haven't applied InvShader to quad1, because we were planning to apply some other shader to quad1. So our process was:
Render Scene2 on Render node --> Apply InvShader on Render node and use it as a texture on quad1 --> apply SomeShader to quad1.
As per our knowledge vizfx.postprocess can be applied to window. We don't know how to apply it on scenes. Please let us know if there is any way.
Thanks!
multi pass, multi-pass, multipass, rendering
Rendering order? vOliver Vizard 3 09-29-2010 02:07 PM
rendering level shahramy Vizard 1 07-26-2010 12:12 PM
how to control vizard rendering shahramy Vizard 0 07-23-2010 10:50 PM
Any way to increase rendering resolution v-Salik Vizard 3 09-12-2007 04:57 PM
Texture map rendering problem JRichizzle Vizard 4 03-04-2004 07:20 AM
