Old 12-11-2003, 04:22 PM
Buster Buster is offline
Rotation
Hello Vizard Experts,
I am a beginner and need some help. Does anybody know a way (or the code) to allow the user's view to remain stationary (or at least the appearance of it) and to make a constellation of points in space rotate at the same time? We want to create an experiment where students watch a constellation of points while it is rotating so they can understand how all the points relate to each other on a 3-D level but we don't want them to move from their position. Is this possible?
Thanks in advance for your help!
Buster
Old 12-11-2003, 04:53 PM
Hi Buster,
If you attach an object to the HEAD then it will always be centered around the viewer. Let's say that your constellations are in a file called 'constellation.wrl', then you would simply do the following:
stars = viz.add('constellation.wrl',viz.HEAD)
Then when you rotate the model it will be rotating around the head, no matter where the viewer moves.
Are you importing the constellations from a model or generating them on-the-fly? If you're generating them on-the-fly then you would simply do something like the following:
viz.startlayer(viz.POINTS)
viz.vertex(...)
stars = viz.endlayer(viz.HEAD)
Look at the file spindots.py in the Vizard20/tutorial/onthefly. It is a simple example of creating a sphere of points and rotating them. Good luck!
