Adding ceiling to 3d room model
I'm trying to build a virtual environment that will look relatively natural for an experiment and could use some help:
I have loaded a model of a room from 3d warehouse but need to add a ceiling for it to look normal Is there a way to add a simple neutral color/ pattern ceiling at a specific height? the room I need it for is pretty big so the ceiling should be long/ with length by demand couldn't find anything suitable on 3d warehouse. Thank you in advanced |
You should be able to load it into SketchUp and make the modification there. There are many online tutorials for SketchUp modeling. The following is a tutorial related to the SketchUp to Vizard workflow:
https://sites.google.com/worldviz.co...-workflow/home |
Tags |
ceiling, color, pattern |
Similar Threads | ||||
adding new model in Vizard | aloktripathi008 | Vizard | 1 | 06-22-2015 03:49 PM |
3ds Exported .IVE Model mirrors movement of Mainview | Felix | Vizard | 9 | 05-18-2012 09:17 AM |
The problem of adding two .ive models | hengshan.li | Vizard | 1 | 08-08-2011 12:04 AM |
Change model alpha and memory leak | hosier | Vizard | 2 | 06-25-2009 10:55 AM |
Awkward neck/shoulder connection when adding custom head to vcc model. | vEsotu | Vizard | 5 | 10-09-2008 05:07 PM |
