Old 08-03-2016, 09:48 PM
Vaquero Vaquero is offline
Red face Crosshatch Post-Processing Effect give away
He there!
As I was digging more into GLSL shader programming and its usage inside Vizard, I implemented the code for a crosshatch post-processing effect as a practice. But I thought, maybe it's useful for anybody, so I share it here.
It also demonstrates how to partially overlay the original image.
Vizard Script:
Crosshatch Post Processing Effect
with adjustable split screen.
import vizcam
vizcam.PivotNavigate(center=[0,1,0],distance=10)
viz.add('piazza.osgb')
import vizinfo
# Setup info panel
info = vizinfo.InfoPanel()
import vizfx.postprocess
class CrosshatchEffect(vizfx.postprocess.BaseShaderEffect):
	def _getFragmentCode(self):
		return """
		uniform sampler2D vizpp_InputTex;
		uniform float scale;
		uniform float vx_offset;
		uniform float hatch_y_offset; // 5.0
		uniform float lum_threshold_1; // 1.0
		uniform float lum_threshold_2; // 0.7
		uniform float lum_threshold_3; // 0.5
		uniform float lum_threshold_4; // 0.3
		void main()
		  vec2 uv = gl_TexCoord[0].xy;
		  vec3 tc = vec3(1.0, 0.0, 0.0);
		  if (uv.x < (vx_offset-0.005))
		    float lum_r = texture2D(vizpp_InputTex, uv).r * 0.2126;
			float lum_g = texture2D(vizpp_InputTex, uv).g*0.7152;
			float lum_b = texture2D(vizpp_InputTex, uv).b*0.0722;
			float lum = scale * length(lum_r + lum_g + lum_b);
			tc = vec3(1.0, 1.0, 1.0);
			if (lum < lum_threshold_1)
			  if (mod(gl_FragCoord.x + gl_FragCoord.y, 10.0) == 0.0)
				tc = vec3(0.0, 0.0, 0.0);
			if (lum < lum_threshold_2)
			  if (mod(gl_FragCoord.x - gl_FragCoord.y, 10.0) == 0.0)
			if (lum < lum_threshold_3)
			  if (mod(gl_FragCoord.x + gl_FragCoord.y - hatch_y_offset, 10.0) == 0.0)
			if (lum < lum_threshold_4)
			  if (mod(gl_FragCoord.x - gl_FragCoord.y - hatch_y_offset, 10.0) == 0.0)
		  else if (uv.x>=(vx_offset+0.005))
			tc = texture2D(vizpp_InputTex, uv).rgb;
		  gl_FragColor = vec4(tc, 1.0);
	def _createUniforms(self):
		self.uniforms.addFloat('scale',1.0)
		self.uniforms.addFloat('vx_offset',0.5)
		self.uniforms.addFloat('hatch_y_offset',5.0)
		self.uniforms.addFloat('lum_threshold_1',1.0)
		self.uniforms.addFloat('lum_threshold_2',0.7)
		self.uniforms.addFloat('lum_threshold_3',0.5)
		self.uniforms.addFloat('lum_threshold_4',0.3)
	def setScale(self,scale):
		self.uniforms.setValue('scale',scale)
	def getScale(self):
		return self.uniforms.getValue('scale')
	def setvx_offset(self,vx_offset):
		self.uniforms.setValue('vx_offset',vx_offset)
	def getvx_offset(self):
		return self.uniforms.getValue('vx_offset')
effect = CrosshatchEffect()
vizfx.postprocess.addEffect(effect)
import vizconfig
# Setup config options for post processing effect
ppConfig = vizconfig.BasicConfigurable('Crosshatch')
ppConfig.addBoolItem('Enable', fget=effect.getEnabled, fset=effect.setEnabled)
ppConfig.addFloatRangeItem('Brightness', [0.5,5.0], fget=lambda: effect.getScale(), fset=lambda v: effect.setScale(v))
ppConfig.addFloatRangeItem('Split Screen', [0.0,1.0], fget=lambda: effect.getvx_offset(), fset=lambda v: effect.setvx_offset(v))
vizconfig.register(ppConfig)
vizconfig.getConfigWindow().setWindowVisible(True)
Source: http://www.geeks3d.com/20110219/shad...g-glsl-filter/
crosshatch, effect, glsl, post-process, shader
Updating a Postprocessing effect MissingAFew Vizard 2 05-07-2015 09:58 AM
