360 video rendering onto background
Hi, I am trying to display 360 video (mp4 file) onto the background using Vizard. Any advice will be truly appreciated!
Thanks! |
You can apply the video to a sphere with normals pointing inwards. Here's an example:
import viz import vizshape viz.go() video = viz.addVideo('sphericalVideo.mp4') sphere = vizshape.addSphere(flipFaces=True) sphere.texture(video) #Play and loop the video video.play() video.loop() #Make sure sphere appears at infinite distance #This allows other objects to be rendered in front sphere.disable(viz.DEPTH_TEST) sphere.drawOrder(-100) #Keep sphere centered around main view viz.link(viz.MainView,sphere,mask=viz.LINK_POS) #Setup a panorama camera navigation import vizcam vizcam.PanoramaNavigate() |
360 video not playing
I tried to get a 360 video to play using the script provided, but all I see is a grey background. Are there some potential things I could take into consideration? Thank you! |
You may not have global codecs for the video type you are playing. Some applications like Windows Media Player have built-in codecs while Vizard relies on global codecs.
Playing a video on a object that is moving. | Jose | Vizard | 8 | 01-29-2015 01:22 PM |
video restarting on right click in architectural interactive | raj | Vizard | 4 | 08-21-2014 01:39 AM |
synching video camera recording with vizard | billjarrold | Vizard | 0 | 12-15-2009 11:43 PM |
Video Background | vvortex3 | Vizard | 5 | 05-29-2009 04:46 PM |
video help | nasr | Vizard | 2 | 05-26-2009 11:42 AM |
