Positioning text with ORTHO parent
I am trying to display some text on a black screen in Vizard. On single screen applications, this is very easy; I just turn the world off and display my text with the screen as the parent, i.e.:
text1 = viz.addText(txt, parent=viz.SCREEN) Code:
text1 = viz.addText(txt, parent=viz.SCREEN, parent=viz.ORTHO, scene = screen.leftWindow) |
You can specify pixel coordinates or link to a window location:
import viz viz.go() #set position in pixel coordinates text1 = viz.addText('text1',parent=viz.ORTHO) text1.setScale([100,100,0]) text1.setPosition([300,200,0]) #link to center top text2 = viz.addText('text2',parent=viz.ORTHO) text2.setScale([100,100,0]) text2.alignment(viz.ALIGN_CENTER_TOP) viz.link(viz.CenterTop,text2) #link to upper left with offset text3 = viz.addText('text3',parent=viz.ORTHO) text3.setScale([100,100,0]) text3.alignment(viz.ALIGN_LEFT_TOP) link = viz.link(viz.LeftTop,text3) link.setOffset([20,-20,0]) |
Ah!
It was pixel coordinates. I was attempting to use the same normalised screen units that worked when I was using viz.SCREEN as the parent so this makes much more sense now. Thanks :-) |
Similar Threads | ||||
Displaying screen text in 3D (Oculus Rift) | pjayaram | Vizard | 2 | 05-27-2014 08:06 PM |
input from a text file | dig | Vizard | 5 | 10-20-2013 01:20 AM |
Informationboxes with text | snoopy78 | Vizard | 3 | 07-16-2009 10:23 AM |
Vizard tech tip: Text to Speech | Jeff | Vizard | 1 | 01-15-2009 09:39 PM |
3d Text with Transparent Borders | vjosh | Vizard | 3 | 12-01-2004 10:50 AM |
