Oculus Rift DK1 setZoom
My apologies for the posting the same question, but I would very much appreciate any of your inputs regarding the Oculus setZoom function. I was using "setZoom" function without any problem using the Vizard 5 Beta, but after installing official Vizard 5, the setZoom function is no longer working. I am using the setZoom function in 360 panorama environment.
Thank you in advance. Code:
import viz import oculus viz.setMultiSample(4) viz.fov(60) viz.go(viz.FULLSCREEN) hmd = oculus.Rift() viz.link(hmd.getSensor(), viz.MainView) # I tested various numbers for hmd.setZoom(), but it is not working... hmd.setZoom = (1.5) env = viz.addEnvironmentMap('C:/Program Files/WorldViz/Vizard5/resources/townhall_L.jpg') sky = viz.addCustomNode('skydome.dlc') sky.texture(env) |
Currently the Oculus setZoom function is not supported. It maybe in a future release of Vizard.
Hi Jeff,
Thank you so much for your response. Does it apply only for DK1 or both DK1 and DK2? Are there other ways to adjust FOV without using setZoom function using Vizard 5? Thank you in advance. |
Similar Threads | ||||
Oculus Rift Drift | teklab | Vizard | 20 | 04-01-2016 07:57 AM |
Oculus Rift and 360 Panorama with Vizard Lite Edition | mshukun | Vizard | 4 | 11-10-2015 11:17 AM |
Oculus Rift connection problem | mshukun | Vizard | 1 | 10-01-2014 12:15 PM |
Oculus Rift Fullscreen | teklab | Vizard | 6 | 05-21-2014 06:11 AM |
oculus rift and inertia cube interaction problems | apboone | Vizard | 4 | 03-13-2014 10:45 AM |
