Old 11-19-2012, 04:39 PM
tokola tokola is offline
Question 'module' object is not callable???
Hi there.
I am trying to do something seemingly simple. I want to have an avatar (steve) attached to different views and I am using the roboChase code in my own Player class (shown below). The class works fine if I run it but not when used as a module. More specifically, when I try to create a new Player object (p1=Player(viz.MainView)) then I get the following error:
  File "<string>", line 2, in <module>
TypeError: 'module' object is not callable
Can you please let me know what is the problem? The error message is kind of cryptic! Also, is there a better way to do the same thing, like linking the avatar with the viewpoint (and avoiding the view through the robot's head)?
import steve
class Player():
	"""This is the Avatar class"""
	def __init__ (self, view):
		self._view = view
		self._player_matrix = viz.addGroup() #self.view.getMatrix()
		self._avatar = steve.Steve()
		self._avatar.setTracker(self._player_matrix)
		self._updateFunc = vizact.onupdate(0, self.Update)
	def UpdatePlayer(self):
		pos = self._view.getPosition(viz.VIEW_ORI)
		quat= self._view.getQuat(viz.VIEW_ORI)
		self._player_matrix.setPosition(pos)
		self._player_matrix.setQuat(quat)
	def Update(self):
		vizact.ontimer(0, self.UpdatePlayer)
Old 11-20-2012, 04:27 PM
Can you post some example code where you import the module, create the Player object and get the error? The following worked fine for me. The only change I made to the module code was import the vizact library.
import PlayerModule
p1=PlayerModule.Player(viz.MainView)
Yes, it's possible to link the avatar to the viewpoint and then offset the avatar from the viewpoint using a link operator.
Old 11-21-2012, 10:48 AM
Thanks a lot Jeff,
it was eventually my carelessness, since I was using another class name not residing in the module
The linking works fine besides the fact that I can't get rid of the robot in the first person view, so it collides with the viewpoint and sends it to outer space! I am using the 'renderOnlyToWindows' command but it doesn't work, I assume because of the linking. If, on the other hand, I get rid of the view collision, then I can get through walls which is undesirable. What's the solution in such cases?
I have a similar problem with a hand cursor I have linked with the view in 3D space (not screen) which is offset 0.2m in front of the view and the view collides on it only when I am moving straight in one of the 4 directions. The only solution I found was to set the collisionBuffer() to zero, but then whenever I am too close to objects the cursor disappears behind them. Also collideNone() applied to the hand object doesn't resolve the problem.
Isn't there a way in both these cases to reset the collision of the object, so that it doesn't collide with the viewpoint?!? It seems such an easy fix but still...
Thanks a lot for your feedback!
'int' object not callable enkeli Vizard 8 10-22-2009 04:12 PM
'ActionData' object is not callable error Enlil Vizard 2 06-09-2008 05:03 PM
