Set a window's position according to viz.WORLD?
Is it possible to take the window (from viz.addWindow) away from viz.SCREEN and apply to viz.WORLD instead? I would like to position the view in the world as though it was a texQuad rather than relative to the screen. (Something like Portal.)
You can use a render node to render the scene to a texture and then apply that texture to any object in the world. Here is a simple example:
import viz import vizact viz.go() # Add environment gallery = viz.add('gallery.osgb') # Add spinning logo logo = viz.add('logo.ive',pos=(0,0,4)) logo.addAction(vizact.spin(0,1,0,45)) # Create render texture tex = viz.addRenderTexture() # Create render node cam = viz.addRenderNode() cam.setSize(512,512) cam.setInheritView(False) cam.setPosition([0.0, 5.87440, 9.62242]) cam.lookAt([0,1,4]) cam.setFov(60,1.0,0.1,100) cam.setRenderTexture(tex) cam.setRenderLimit(viz.RENDER_LIMIT_FRAME) # Apply render texture to gallery painting gallery.texture(tex,node='painting_starry-night') |
joystick position | nmohandes | Vizard | 2 | 01-16-2012 10:03 AM |
Dynamic Position and Radius of Sphere | hotshotiguana | Vizard | 1 | 03-23-2011 12:53 PM |
Translate view from sensor position to lens position? | Kaminski | Vizard | 4 | 03-09-2011 10:36 AM |
default start position | erchrastil | Vizard | 2 | 06-23-2008 08:15 AM |
Avatar always returns in initial position | pattie | Vizard | 2 | 08-31-2006 08:15 PM |
