Old 01-25-2012, 02:33 AM
sxu04 sxu04 is offline
Reading in columns
Hi, I'm hoping someone can help
I have a text file that I need to read in, and I want to be able to loop through both rows and columns
Column 1 and 2 in the text file contains a list of 64 numbers relating to 64 x and y positions. Column 3 contains a list of 64 numbers (either 1 or 2) that relates to a certain action in my vizard code.
Currently, I can loop through each row in columns 1 and 2 checking whether these values match their current position, when it matches - the number in the corresponding row in column 3 is read in and the action is carried out.
So far so good, but rather than having just one 'action' column I actually have 100+ action columns (columns 3 -100+) and I want to create a loop where each step in the loop reads the next action colomn in the text file
Any help would be most appreciated!
currentX=[]
currentY=[]
action=[]
file = open('data.txt', 'r')
for line in file:
	s=line.split()
	currentX.append(float(s[0]))
	currentY.append(float(s[1]))
	action.append(float(s[2]))
def movement(key):
	currentpos = viz.MainView.getPosition()
	for i in range(0,64):
		if currentpos==[currentX[i],1.0,currentY[i]]:
			if action[i]==1:
reading USB I/O shuva93 Vizard 0 06-07-2011 01:37 PM
Using wordwrap or reading in newline (\n) comands from a .txt document EnvisMJ Vizard 1 04-04-2011 03:52 PM
Reading sensor data via UDP Jeethridge Plug-in development 1 08-24-2010 10:51 AM
Reading form serial port strangeness nige777 Vizard 6 06-22-2010 12:04 PM
csv reading kgarr Vizard 1 02-27-2006 12:02 PM
