Phantom omni Vs Vizard
Dear sir,
I have installed PDD driver version 3 to connect phantom omni to my desktop. Since I am using Windows XP 64 edition, version 3 driver is appropriate. But I am unable to use vizard with this version. Can you provide me a solution to use vizard software with version 3? Version 2 is not supporting to 64 edition. I would appreciate your reply. Thanks in advance Blesson Isaac Research Assistant Praire View A M University |
Vizard will work with the phantom and XP 64 bit. Make sure you first install the PDD drivers for 64 bit, then you install and license OpenHaptics 2.0.
Hi Jeff,
Thanks a lot. Now its working. Yes vizard works with phantom and xp 64 bit. After the PDD driver is installed we need to install the OpenHaptics 2.0 Thanks, Blesson Isaac |
Similar Threads | ||||
Phantom, Vizard 3.0, OpenHaptics 3.0 | vEsotu | Vizard | 2 | 02-02-2011 09:04 PM |
Vizard 4 Beta Testing | farshizzo | Announcements | 0 | 02-01-2011 10:46 AM |
Vizard 4 Beta Testing | farshizzo | Vizard | 0 | 02-01-2011 10:46 AM |
Vizard tech tip: Using the Python Imaging Library (PIL) | Jeff | Vizard | 0 | 03-23-2009 11:13 AM |
SenseAble Phantom set up with Vizard | jfreeman | Vizard | 1 | 06-01-2005 10:27 AM |
