Old 03-17-2011, 12:19 PM
pcatalano pcatalano is offline
Question Peek Effect in Inspector
Inspector is a really handy little tool, thanks for including it in Vizard 4.
The visual effect when you turn "peek" on is nice (unselected objects are faded out). Is it possible to replicate this effect in Vizard?
Old 03-17-2011, 03:44 PM
The peek feature requires low-level access to the scene graph, so you won't be able to fully replicate this feature using built-in Vizard commands.
Basically, it renders the entire scene as usual, then renders a semi-transparent quad over the screen that is the same color as the background. This is what makes everything look faded. Finally, it renders just the selected node. This last part requires some low-level tricks in order for the selected node to appear correctly.
Glow effect on a texture? Renato Lima Vizard 5 10-25-2010 04:27 AM
special effect shahramy Vizard 1 06-14-2010 03:22 PM
How can I do the flip effect of poker? superantTTY Vizard 2 05-27-2010 01:15 AM
exporting snow(particle effect) from 3dstudiomax to vizard virtmeg Vizard 3 09-15-2004 02:38 PM
The effect of lighting on performance JRichizzle Vizard 1 06-18-2004 10:40 AM
