Old 08-23-2010, 07:41 PM
arscarsc arscarsc is offline
Send a message via MSN to arscarsc
the difference between transform matrix and setEuler,setPosition,setScale
I don't understand what is the difference between transform matrix and setEuler,setPosition,setScale. In order to explain explicitly, we can use the following code as an exmaple
(1)import viz
logo = viz.add('logo.wrl')
logo.setPosition(0,0,10)
logo.setEuler([90,0,0])
(2)import viz
import vizmat
x = vizmat.Transform()
x.makeAxisAngle(0,1,0,90)
logo.setMatrix(x)
Old 08-24-2010, 09:17 AM
The node.setMatrix command sets the entire transform matrix of the node, which includes position, rotation, and scale. The individual setPosition, setEuler, setScale, etc.. command only affect that specific attribute.
In your first example, the position of the object will be (0,0,10) after the call to setEuler.
In your second example, the position of the object will be (0,0,0) after the call to setMatrix, since you didn't specify a position value for the matrix.
Quat to matrix in Python 2.4 aghena Vizard 2 07-21-2010 09:24 AM
Matrix Transform and Bumpmap GiudiceLab Vizard 0 11-27-2009 12:42 PM
linear transform in 2D screen space stefs Vizard 1 10-09-2009 10:15 AM
tracker coordinates transform Charlotte Li Vizard 1 05-18-2009 02:38 PM
Transform object & matrices david Vizard 4 03-27-2003 09:18 AM
