Old 06-27-2010, 12:50 AM
znchb znchb is offline
Question how to "spin/spinto" an rectangular around its center or edge?
Please see the program below, I build an rectangular using polygon, and I want to make it spin around its Center point or around its Edge Line of rectangular ?
Is there anyone would like to help me?
Thank you very much!
viz.clearcolor(viz.WHITE)
bg = viz.add('tut_ground.wrl')
pos = bg.getPosition()
viz.MainView.setPosition(pos[0],pos[1]+5,pos[2]-20)
A = [pos[0]-2, pos[1]+8, pos[2]+10 ]
B = [pos[0]+2, pos[1]+8, pos[2]+10 ]
C = [pos[0]+2, pos[1]+4, pos[2]+10 ]
D = [pos[0]-2, pos[1]+4, pos[2]+10 ]
viz.startlayer(viz.POLYGON)
viz.vertex(A)
viz.vertex(B)
viz.vertex(C)
viz.vertex(D)
Rectangular = viz.endlayer()
Rectangular.color(viz.RED)
#make it spin/spinto
#Rectangular.addAction(vizact.spinto(0,0,1, 180, 30))
Rectangular.addAction(vizact.spin(0,0,1, 90))
#---- How to make it spin around the Center of the rectangular ?-------
#---- or how to make it spin around the Edge Line of rectangular ? -----
Old 06-27-2010, 07:25 PM
Is there anyone can help me? I really need to solve this problem, which is one function of my project.
I will be very appreciated.
Old 06-28-2010, 09:45 AM
You should create the rectangle so that it is centered around the axis you want it to rotate about. Instead of adding the position to the vertex positions, specify the vertices so they are centered about the origin (0,0,0), and then add the position to the entire model using the Rectangular.setPosition command.
Changing pivot center midway through animation vijaykiran Vizard 2 10-19-2009 10:10 AM
Edge Blending in Vizard realvision Vizard 2 03-25-2008 09:32 AM
Positioning objects: center johannes2 Vizard 2 02-12-2008 02:56 AM
Center Viewport on Object (5DT Glove) bjgold Vizard 3 07-25-2006 03:22 PM
