Old 10-24-2012, 12:26 PM
davev davev is offline
Problem reading VRPN info from ZSpace
I am attempting to read tracker data from a ZSpace system in Vizard. I am able to connect to the VRPN server using the vrpn_print_devices program provided with VRPN. When I connect using the same tracker and server name from Vizard I always get [0.0, 0.0, 0.0] for the tracker position.
Attached is a screenshot showing the output from vrpn_print_devices on the left and my vizard code and output on the right.
It looks like the tracker does provide more data than just the position and quaternion. Could this be a problem when using the tracker from Vizard?
Old 10-24-2012, 12:32 PM
Your while loop is blocking the main update loop, so the tracker will never update. You should never use time.sleep in the main thread. Instead, register a function to be called every 0.25 seconds and print the tracker values within that function:
def PrintValues():
    print glasses.getPosition()
    print glasses.getQuat()
vizact.ontimer(0.25,PrintValues)
Old 10-24-2012, 12:45 PM
Thanks! That did the trick.
infinite, vrpn, zspace
VRPN info sdiverdi Precision Position Tracker (PPT) 5 01-16-2011 12:00 PM
The problem of tracker using via VRPN _kj_ Vizard 2 08-13-2009 12:03 AM
Turning info boxes on and off Karla Vizard 2 12-17-2007 03:13 PM
