Old 08-31-2009, 02:55 PM
whj whj is offline
Real-time export data to simulink
I'm seeking a solution to output position and orientation data to another computer running Simulink in real time. Does anybody have any experience?
Thanks!
Old 09-03-2009, 04:48 PM
Can Simulink read data coming over a network socket? If so, you can use the Python socket module to send data over the network.
Old 09-04-2009, 09:32 AM
whj whj is offline
I found a UDP Receive block in Simulink. It requires the other end of the communication, which is vizard, to specify the port that receives data. I'm not sure how to do it. I think my code only specifies the port that sends data. Am I missing something?
import socket
COMPUTER_IP_ADDRESS = socket.gethostbyname('192.59.88.91')
PORT = 25000 #The port to send data on
OutSocket = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
OutSocket.setsockopt(socket.SOL_SOCKET, socket.SO_REUSEADDR, 1)
def SendData(data):
	OutSocket.sendto(data,(COMPUTER_IP_ADDRESS,PORT))
vizact.onkeydown(' ',SendData,'hello there')
Thanks!
Old 09-04-2009, 04:29 PM
This post shows how to send and receive data on UDP sockets using different ports.
Old 09-05-2009, 08:49 PM
whj whj is offline
I'm confused, in the sample code, there is only one port 4999, which is "#The port to send/receive data on". Why does it show using different ports? Thanks.
Old 09-08-2009, 12:51 PM
whj whj is offline
So far I'm sure simulink on computer B can receive data from specified IP address and port over UDP. Then my question is, how do I specify the port that the remote computer B accepts data from in vizard on this computer A? Thanks.
Old 09-08-2009, 02:31 PM
whj whj is offline
I just got them communicated successfully. PORT = xxxx seems to be used to specify the remote port to receive from. Please forget my previous question.
My next problem is I would like to send two values from vizard to simulink every 0.05 second. My code would be like this:
import socket
import random
COMPUTER_IP_ADDRESS = '129.59.82.229'
PORT = 25000
def SendData(data):
def mytimer(num):
	value1 = random.randint(0, 70)
	value2 = random.randint(1, 100)
	SendData(value1, value2)
viz.callback(viz.TIMER_EVENT, mytimer)
viz.starttimer(0,0.05,viz.FOREVER)
I know SendData(value1, value2) wouldn't work. Could somebody tell me how to use SendDate at this context.
Thanks a lot.
Old 09-09-2009, 12:16 PM
When sending data using the socket module, the data needs to be a string containing the raw byte data. Have a look at the Python struct module for packing Python integer/float values into raw byte data. The following example shows how to generate raw byte data from 2 integer values:
import struct
data = struct.pack('ii',value1,value2)
Old 09-11-2009, 09:33 AM
whj whj is offline
Thanks a lot. That really helps.
real time collision on animation path whj Vizard 10 10-06-2008 04:38 PM
Real Time Audio Data lomendil Vizard 2 06-02-2008 08:18 PM
Can I get real time Intersense tracking data from another computer on the network? GoldenSun Vizard 4 04-30-2008 07:42 PM
Flagging the Data Elittdogg Vizard 5 04-11-2008 11:40 AM
