Old 04-29-2003, 01:40 PM
FlyingWren FlyingWren is offline
viz.eyeheight ( )
The command viz.eyeheight does not seem to be working as I expect.
The helpfile says, "Normally, issuing viz.reset(viz.HEAD_POS) will reset the view model to (0, 1.82, 0). The eyeheight command changes the Y value and will affect subsequent resets."
Yet, when I do a reset, whatever I punched into the viz.eyeheight() does not seem to matter; the eye height is effectively set to 0 regardless of what I set to be the eye height previously (plus the position sensor's value, if it's being used).
Am I doing something wrong? Here's my code (minus some formatting that gets lost in this bulletin board):
# [snipped stuff here]
if testing:
viz.go(viz.MONO)
viz.go(viz.HMD | viz.STEREO)
viz.eyeheight(5.0)
# [more code in here, snipped]
def KeyboardFunction(key):
if key == 'r':
viz.reset(viz.HEAD_ORI)
viz.reset(viz.BODY_ORI)
as mentioned, pressing 'R' sets my view height to 0 + (position sensor, if used).
Old 04-29-2003, 05:22 PM
Would you mind including the portion of your code that uses
the sensor?
farshid
