how to clear background sound of an animation
#the following program try to clean the animation-teacher and the sound,
#but I can't perform the later one, could you please help me? Thanks import viz import vizact viz.go() viz.clearcolor(viz.SKYBLUE) viz.add('tut_ground.wrl') teacher = viz.add('c:\\Program Files\\WorldViz\\Vizard30\\resources\\vcc_female.c fg') teacher.translate(1,1,1) viz.MainView.translate(0,2,-10) teacher.setEuler(-180,0,0) teacher.state(14) #speech = vizact.speak('c:\\Program Files\\WorldViz\\Vizard30\\resources\\carousel.wav ') teacher.addAction(vizact.speak('c:\\Program Files\\WorldViz\\Vizard30\\resources\\carousel.wav ')) def clean(): teacher.clearActions()#vizact.speak) teacher.remove() vizact.onkeydown(' ', clean) |
Try the following to end the sound in the middle of running a speak action. In order to preserve the indentation of your code use the code tags the next time you post some code.
import viz viz.go() viz.clearcolor(viz.SKYBLUE) viz.add('tut_ground.wrl') teacher = viz.add('vcc_female.cfg', pos = [0,0,5], euler = [180,0,0]) teacher.state(14) speech = vizact.speak('carousel.wav') teacher.addAction(speech) def clean(): teacher.clearActions() teacher.remove() viz.playsound('carousel.wav', viz.STOP) vizact.onkeydown(' ', clean) |
Similar Threads | ||||
Sound Looping Problem | JMOwens | Vizard | 4 | 09-29-2010 09:42 PM |
Stuttering sound | Jerry | Vizard | 1 | 06-13-2007 12:36 PM |
Animation Tracks.... | k_iwan | Vizard | 2 | 03-26-2007 05:52 PM |
avatar animation problems | jrodman | Vizard | 1 | 01-18-2006 09:12 AM |
sound problem | alaa | Vizard | 7 | 09-02-2005 01:13 PM |
