Old 08-26-2009, 07:03 AM
sl0bz sl0bz is offline
Viewpoint Compass
I am creating an application that has a pretty large CAD model and when the users are navigating through the model there have been complaints that they are losing track of where they are in the model. I want to create a "you-are-here" type window that the user can pop up on the screen.
I have been experimenting with addWindow() and addView() to get a top down view of the environment. I would like to be able to insert an arrow over this window that follows the position and orientation of the main viewpoint. Is this possible?
Thanks!
Patrick
Old 08-28-2009, 03:06 PM
Here is a sample script that shows how to overlay objects on a sub-window:
#Add the room and arrow
room = viz.add('gallery.ive')
# Create a new window in the upper left corner
UpperLeftWindow = viz.addWindow(pos=(0,1.0),size=(0.2,0.2))
UpperLeftWindow.visible(0,viz.SCREEN)
# Create a new viewpoint
BirdView = viz.addView()
#Attach the bird's eye view to the upper left window
UpperLeftWindow.setView(BirdView)
#Move the view above the center of the room
BirdView.setPosition([0,9,0])
#Rotate the view so that it looks down
BirdView.setEuler([0,90,0])
#Overlay arrow on sub window (20x20 pixels)
arrow = viz.addTexQuad(parent=viz.ORTHO,scene=UpperLeftWindow,size=20)
arrow.texture(viz.add('arrow.tif'))
def UpdateArrow():
	#Get the current head orientation and position
	yaw,pitch,roll = viz.MainView.getEuler()
	pos = viz.MainView.getPosition()
	# Place arrow on top of viewpoint
	x,y,z = UpperLeftWindow.worldToScreen(pos,mode=viz.WINDOW_PIXELS)
	arrow.setPosition([x,y,0])
	# Rotate arrow to match yaw rotation
	arrow.setEuler([0,0,-yaw])
vizact.ontimer(0,UpdateArrow)
Old 09-02-2009, 12:27 PM
That worked well for me, thanks for your help!
How to track the actual viewpoint Jerry Vizard 3 05-25-2016 09:44 AM
Draw Vector in viewpoint lookat direction Chrissy2009 Vizard 2 05-30-2009 12:50 AM
Avatar w/ hat cannot look at viewpoint TrashcanPatrol Vizard 5 08-19-2008 08:26 AM
3d viewpoint movement spacefarer Vizard 9 07-25-2006 03:37 PM
VRML Viewpoint error bstankie Vizard 1 03-11-2003 02:10 PM
