Old 02-21-2010, 08:32 PM
hankiwan hankiwan is offline
Question transparency control
I would like to embody gradient transparency.
Yes, I could set alpha or transparency by <node3d>.alpha, but the alpha value is applied in all object.
Is there any method to control alpha values in pixel by pixel on screen or image?
Can I manage alpha map in Vizard? If it is possible, how can I handle it?
Regards.
Old 02-14-2012, 07:02 AM
nabrahamson nabrahamson is offline
Regards.
You may want to try setting your alpha the following way:
<node3d>.alpha(<alpha value>, op=viz.OP_OVERRIDE)
However, doing this may cause you to lose color values. It's likely that you will have to re-apply the color after you set your alpha this way.
Camare control question(about separated eye view) atamasan Vizard 3 01-28-2010 06:22 PM
version control? billjarrold Vizard 1 01-26-2010 09:39 PM
adding more than 1 action for avatar animation slider control yak Vizard 0 07-21-2009 11:22 AM
Control of timers vizmaster Vizard 6 08-22-2008 09:36 AM
intersense: Failed to set control word on \\.\COM1 OueOue Precision Position Tracker (PPT) 2 01-18-2007 12:51 PM
