PanoramicHelp
Hello!
I am new to the worldviz and I am just learning Python. I work in a biomechanics lab and we are re-creating virtual environments for work with rehabilitation techniques. I am attempting to re-create a lab setting using standard .jpg pictures that I have taken of the lab. I completed the tutorial, however when I substitute the picture call in the script it continues to show the tutorial model. My main question is: 1) How can I route the script to the pictures that I choose instead of the worldviz tutorial model? Thanks |
Which tutorial did you use for this? Can you post some example code?
Panorama Help
Hello Jeff,
I used the following code import viz viz.go() env = viz.add(viz.ENVIRONMENT_MAP,'lab_L.jpg') sky = viz.add('skydome.dlc') sky.texture(env) I essentially substituted the 'townhall_L.jpg' for lab_L.jpg' The lab .jpg files were copied to the directory that the townhall jpgs are contained with the exact same file parameters, eg lab_negx etc The tutorial used was Tutorial: 360 Panoramas |
Thread Tools | |
Display Modes | Rate This Thread |
