Old 09-16-2010, 04:48 AM
kay kay is offline
Change position of MainView after COLLISION_EVENT
hi,
I would like to set the MainView to a new position after there was a COLLISION_EVENT. Calling viz.MainView.setPosition(...) leads to a "RuntimeError: maximum recursion depth exceeded".
viz.collision(viz.ON)
def onCollision(info):
	viz.MainView.setPosition([0,0,0])
viz.callback(viz.COLLISION_EVENT,onCollision)
Using viz.MainView.reset(viz.HEAD_POS) works. But how do I change the reset position? The default is (0,1.82,0).
Thank you very much for suggestions.
Old 09-16-2010, 11:54 AM
You're getting that error in the first piece of code because the viewpoint is being placed in a location that causes a collision when the collision event occurs.
In the second piece of code the viewpoint is set to [0,1.82,0] unless the eyeheight has been changed. That command will always move the view above the origin.
If you want to move the viewpoint somewhere else use
viz.MainView.setPosition()
but make sure the position is not at ground level or colliding with another object.
Old 09-17-2010, 03:59 AM
kay kay is offline
hi jeff,
I tried viz.MainView.setPosition() with other positions (non-colliding!), e.g., simply
	viz.MainView.setPosition([0,1.82,0])
I still get the "RuntimeError: maximum recursion depth exceeded". Calling viz.MainView.setPosition(), e.g.,
also leads to the RuntimeError.
Any other ideas? Isn't possible to change the default of viz.HEAD_POS?
Old 09-17-2010, 02:21 PM
What do you have loaded in your scene? Can you post an example script that reproduces the error?
Old 09-23-2010, 05:09 AM
kay kay is offline
hi,
i tried to find a reproducible example. The maximum recursion depth error doesn't appear allways. Often everything work smoothly now.
However ... use either the intialPos inside the tunnel and go to the outside and collide with it or use the outside initialPos and collide with the inside of the tunnel in the example below. The error should appear then.
ob=viz.add('playground.wrl')
ob.setScale(1.5,1.5,1.5)
#initialPos=[14.,0.75,13.5]  # inside tunnel
initialPos=[6.,0.75,13.5]    # outside tunnel
viz.MainView.setPosition(initialPos)
viz.MainView.eyeheight(initialPos[1])
print viz.MainView.getPosition()
    print "collision at ", info.point
By the way, here is the full error, maybe this helps to understand what's happening:
File "<string>", line 0, in ?
File "C:\Program Files (x86)\WorldViz\Vizard30/python\viz.py", line 367, in __init__
self.object = _GetNode(data[7])
Old 10-07-2010, 05:06 PM
masaki masaki is offline
Try turning collision off before changing the view position, then turn it back on.
	viz.collision(viz.OFF)
Best,
Masaki
Change model alpha and memory leak hosier Vizard 2 06-25-2009 10:55 AM
writing joystick position to a data file Saz Vizard 3 12-17-2008 05:18 AM
How can you dynamically change the gain on a tracker-based CaveView? michaelrepucci Vizard 2 09-23-2008 07:18 AM
Avatar always returns in initial position pattie Vizard 2 08-31-2006 08:15 PM
