Old 06-30-2010, 01:58 PM
imperialkat imperialkat is offline
Looking for a shape
For a model I'm working on I need a shape that looks like a cone with its tip cut off. I want to be able to control the diameter of both sides. Is there a way to achieve this in Vizard?
Old 06-30-2010, 02:02 PM
import vizshape
myshape = vizshape.addCylinder(height=1.0,bottomRadius=0.5,topRadius=0.1)
Old 07-02-2010, 12:01 PM
Alright, that was what I was looking for. Now I want to manipulate it from within the program. This is what I have:
import vizshape
viz.MainView.setPosition(0,0,-4)
slider = viz.addSlider()
slider.setPosition(0.2, 0.1)
slider.set(0.1)
def onSlider():
	x = slider.get()
	print x
	myshape = vizshape.addCylinder(height=1.0,bottomRadius=0.5,topRadius=x)
vizact.onupdate(0, onSlider)
But when I move the slider the top of the cone only gets bigger, not smaller. What am I doing wrong?
Old 07-05-2010, 03:06 PM
You'll need to remove the cylinder you already added to see the new clinder you add with a smaller radius:
import vizshape
slider.set(0.1)
def changeRadius(pos):
	global myshape
	myshape.remove()
	myshape = vizshape.addCylinder(height=1.0,bottomRadius=0.5,topRadius=slider.get())
vizact.onslider(slider, changeRadius)
Old 07-06-2010, 12:02 PM
Thanks, that works well. I was just wondering if there was an easier way to do that--i.e., instead of erasing cones and rendering new ones, could I call, say, the topRadius with a command and change it?
