Old 04-23-2010, 12:16 PM
Attached is a folder containing a plug-in and a python module that loads this plug-in to control OSG animations based on simple transformations(translation,rotation,scale). Also in the folder is an example script that uses the python module.
For controlling complex animations you can export to the Cal3D avatar format. In Vizard you could either play animations or animate between morph targets.
