I wonder if someone can help me, I am trying to set up a semi-circle array of positions on the left hand side of the screen, depending on how many distractors are selected (e.g. either 2, 4, 6 or 8) each position should contain one target object and the rest distractors, these should be randomised. I then want the target position to be a hotspot. But at this stage I'm having trouble just getting an array of positions where I want them with the correct objects in them.
Any help would be hugely appreciated.
Thank you.
import viztask
import random
Z_dist = -5
#viz.move(0,0,Z_dist)
viz.MainView.move(0.5,0,-10)
# Add distractor and target objects
ballsize = [2.0,2.0,2.0,1.0,1.0,1.0]
# Distractor ball
distractor = viz.add('soccerball.ive')
distractor.setScale(ballsize[0],ballsize[1],2)
distractor.addAction(vizact.spin(0,1,0,100))
# Target Ball
target = viz.add('ball.wrl')
target.setScale(ballsize[3],ballsize[4],1)
target.addAction(vizact.spin(0,1,0,100))
# Set up zones for the objects to appear on the screen
choice = ['2', '4', '6', '8']
select = viz.choose('How many distractors?', choice)
#make a list with the objects in it
objects = [distractor,target]
# keep 2 positions in an array
pos = [[-1.0,0.0,Z_dist],[-1.0,0.5,Z_dist],[-2.0,1.0,Z_dist],[-1.0,1.5,Z_dist],[-1.0,2.0,Z_dist],[-1.0,2.5,Z_dist],[-1.0,3.0,Z_dist],[-1.0,3.5,Z_dist]]
rand_positions = []
def sceneOn(num):
global rand_positions
positions = [0,1,2,3,4,5,6,7]
if select == 0:
#set objects to 2 different random positions
rand_positions = random.sample(positions,2)
objects[0].setPosition(pos[rand_positions[0]])
objects[1].setPosition(pos[rand_positions[1]])
if select == 1:
#set objects to 4 different random positions
rand_positions = random.sample(positions,4)
objects[0].setPosition(pos[rand_positions[1]])
objects[0].setPosition(pos[rand_positions[2]])
objects[1].setPosition(pos[rand_positions[3]])
if select == 2:
rand_positions = random.sample(positions,6)
objects[0].setPosition(pos[rand_positions[3]])
objects[0].setPosition(pos[rand_positions[4]])
objects[1].setPosition(pos[rand_positions[5]])
if select == 3:
rand_positions = random.sample(positions,8)
objects[0].setPosition(pos[rand_positions[5]])
objects[0].setPosition(pos[rand_positions[6]])
objects[1].setPosition(pos[rand_positions[7]])
sceneOn(1)
