Please use the [code][/code] tags when posting code samples on the forum. It preserves the indentation, which is necessary for Python code.
I believe somebody else ran into this issue as well and I posted the fix for it. In case you cannot find it, here is the code again that should work in stereo mode.
viz.go(viz.STEREO)
REFLECT_MASK = viz.LAST_MASK << 1
def addMirror(mirror,mat=None):
#If mirror matrix is not specifed, get matrix of mirror object
if mat is None:
mat = mirror.getMatrix()
#Position of mirror
pos = viz.Vector(mat.getPosition())
#Direction mirror is pointing
dir = viz.Vector(mat.getForward())
dir.normalize()
#Quaternion rotation of mirror
quat = mat.getQuat()
for eye in (viz.RENDER_LEFT,viz.RENDER_RIGHT):
#Create render texture
tex = viz.addRenderTexture()
#Create render node for rendering reflection
lens = viz.addRenderNode(size=[1024,1024])
lens.setCullMask(REFLECT_MASK)
lens.attachTexture(tex)
lens.setInheritView(True,viz.POST_MULT)
lens.disable(viz.CULL_FACE,op=viz.OP_OVERRIDE)
lens.disable(eye)
#Setup reflection matrix
rot = viz.Matrix.quat(quat)
invRot = rot.inverse()
lens.setMatrix(viz.Matrix.translate(-pos)*invRot*viz.Matrix.scale(1,1,-1)*rot*viz.Matrix.translate(pos))
#Setup reflection clip plane
s = -viz.sign(viz.Vector(dir) * viz.Vector(pos))
plane = vizmat.Plane(pos=pos,normal=dir)
dist = plane.distance([0,0,0])
lens.clipPlane([-dir[0],-dir[1],-dir[2],s*dist+0.1])
#Project reflection texture onto mirror
mirror.texture(tex)
mirror.texGen(viz.TEXGEN_PROJECT_EYE)
#Add gallery environment
#Use existing painting as mirror and specify the matrix
mirror = gallery.getChild('art04-FACES')
m = viz.Matrix()
m.setPosition(mirror.getPosition(viz.ABS_GLOBAL))
m.setEuler(180,0,0)
#Apply mirror settings to mirror object
addMirror(mirror,m)
#Increase ambient lighting
viz.MainView.getHeadLight().ambient(1,1,1)
#Create a self avatar
avatar = viz.add('vcc_female.cfg')
#Link avatar body to viewpoint
avatarLink = viz.link(viz.MainView,avatar)
avatarLink.setPos([None,0,None]) #Keep avatar on floor
avatarLink.setEuler([None,0,0]) #Only update avatar yaw
avatar.setMask(viz.LEFT_MASK|viz.RIGHT_MASK,mode=viz.MASK_REMOVE) #Only draw avatar in mirror
#Link avatar head to viewpoint
head = avatar.getBone('Bip01 Head')
head.lock()
viz.link(viz.MainView,head,mask=viz.LINK_ORI)
