If you want to know when a slider is released, then handle the viz.BUTTON_EVENT and check for the slider object. Example:
slider = viz.addSlider(pos=(0.5,0.1,0))
def onButton(obj,state):
if obj == slider and state == viz.UP:
print 'slider released'
viz.callback(viz.BUTTON_EVENT,onButton)
If you still need to handle the mouse up event, then you need to register your callback with a lower priority number than the GUI priority. Example:
def onMouseUp(button):
print 'left button released'
viz.callback(viz.MOUSEUP_EVENT,onMouseUp,priority=viz.PRIORITY_GUI_HANDLER-1)
