There is actually a new undocumented feature of the plug-in API that allows you to specify the size of the data field. First download the newer version of
sensors.h
Then in your
InitializeSensor function you can set the size of the data field by doing the following:
((VRUTSensorObj *)sensor)->dataSize = 20;
Now the data field can hold up to 20 values and calling the
get function in your script should return 20 values.
Another way is to do as you suggested and create a separate plug-in for the wand. Hope this helps.
