Does this happen when you use the oculusExample.py (File > Quick Open > type: oculusExample) included with Vizard. Are you running in direct HMD or extended mode? Which version of the oculus runtime are you using? This could be related to graphics drivers. You might try updating or rolling back the driver version to see if that helps.
