Old 09-02-2005, 02:22 PM
Johannes Johannes is offline
Thank you!
1. As the grid is just a texture on a quad I did
gridCoord= viz.add('../resources/joNew/gridLevel5.jpeg')
quad.texture(gridCoord)
quad.disable(viz.LIGHTING)
But it did not help (see attached picture).
2. Are you calling viz.go() in your main script and your module? viz.go() should only be called in the main script.
Yes, I know that I should call viz.go() only in the main script. But if I do not also call it in the module it will not show me the balls that should... If I do call viz.go() in the module it works fine but I know this is not correct!
Johannes
