If the display is parented to another object in Vizconnect, then the link will override the viewpoint command in Vizard. From Vizconnect, you can add a post trans offset in the Offsets dialog for the PPT Tracker to adjust the height. Take a look at the
Displays and Trackers tutorial for an example using offsets.
