Dear community,
I'm having issues retrieving data from an ASL EyeTracker. Everything works fine, uploading and calibration, until I try to get the data. After calibrating, I save the config as asl.xml in the same folder as the script supposed on [1], which raises an error when I try to run it:
ERROR: Failed to connect to ASL EyeTracker (Cannot create XML parser.
Please install MSXML4 from http://msdn.microsoft.com/XML/XMLDownloads)
ERROR: Failed to create extension sensor with asl.dle
MSXML4 is installed. Am I missing some import or did I forget something crucial?
Thanks very much, regards
[1]
http://docs.worldviz.com/vizard/ASL_Eye_Tracker.htm
